Ross Theobald
Likewise4 - I'll buy a spare if the price is reasonable.
Try here:
https://www.heimwerkertools.com/hae...olzdicken-ab-11-mm-fuer-unsichtbaren-anschlag
Brass or nickel plated. €9.30 plus €8.90 delivery to GB.
Try here:
Probably a bit late but I have several spare from broken tops over the years. Contact me if anybody needs oneI have managed to break or at least displace one of the hinges on the glass top over the cooker/sink. I see from some posts of April 2015 that a replacement VW hinge costs £46 (!) but PMRM suggests using a similar hinge Sepa Thin, possibly available from Hafele. However, I have not been able to find anything similar.
Does anyone know where a replacement hinge might be obtained, ideally one that I can afford? Thanks.
found 'start conversation' but it won't allow it to send??Yes please, can’t for the life of me find how to send you a direct message.
Thank you! Have found the OConner website (very interesting), and sent a message thru there.Ed ... he is not a vip member so u can't message him, I've tagged him so when he logs in he will see your message ... i wouldn't put your phone number up if i were u
Cheers for posting, much appreciated, 3 ordered.Try here:
Haven't had bolts getting loose in mine?I’ve worn my holes out. Manage to retap the threads to a bigger size and sourced som nice stainless bolts. Problem fixed. It is really easy to cross thread the small M3 (?) bolt and ruin the holes...in addition they come often loose wiggling in the hole, and slowly destroy the threads. I’ve used blue loctite on mine...
Hi, Can anyone help me by pointing me towards the specific part - I have had a look on the website and cant find it. Or if there is anywhere else to buy the hinges for the fridge other than VW. thanksCheers for posting, much appreciated, 3 ordered.
I have some you can have one freeI have managed to break or at least displace one of the hinges on the glass top over the cooker/sink. I see from some posts of April 2015 that a replacement VW hinge costs £46 (!) but PMRM suggests using a similar hinge Sepa Thin, possibly available from Hafele. However, I have not been able to find anything similar.
