Dipped headlight fault
bigmac77
bigmac77
North Wales
T6 Ocean 199
A quick heads up, I had a warning light on the dash to say I had a bulb out so a quick inspection revealed the dipped headlight drivers side wasn’t working. The next day I take out the bulb and it looks fine, on further inspection I find the bulb holder is partially melted. I ordered a replacement and now all is fine. I nearly ordered new bulbs which would have been £20 wasted.
Thanks for the info.
Although all my lights still working. And mine is 4 years older.
You have the H7 headlights like mine?
Yes it was the H7 bulb holder. The parts company said it was a commen fault, also on the Golf.
Our dip went on our last trip. Upon inspection It was clear something was not well. The spade connection had melted which I have rightly or wrongly assumed to be a loose connection arcing. I’ve ordered a new connector, but thank you for the post as I didn’t check the bulb holder, just assumed it was blown. one thought - should I solder the new connector in place or crimp. Brown positive?
.View attachment 51685
Brown is normally earth.
Cheers Andy, I thought so. When I fitted the new connector I put the old lamp back in and hey presto it worked. Just shows that one should never assume
Y
Perfectos
Perfectos
ThisIsChristoph
5K
B J G
B J G
G
Graeme Arnott
G
