Cameron1960
- Messages
- 117
- Vehicle
- Caddy California
Someone very kindly stole both my water filler cap keys. Any suggestions as to how I can get the cap off?
Good logic but you don't want to end up with metal swarf in the tank, so a tricky one.Worth trying to drill out the lock before applying too much force. You could end up damaging the filler neck.
Locksmith might be able to helpSomeone very kindly stole both my water filler cap keys. Any suggestions as to how I can get the cap off?
My job for today when the rain stops!Sorry Cameron,
Have been away with no email for a week. You have probably fixed it by now, but if you haven’t............
Drill a 2mm hole Starting about 3mm in from the outer edge of the cap (just inside of the radiused corner) and angle the drill slightly towards the edge of the cap.
After the outer black cap you should hit the blue plastic of the inner mechanism (the blue swarf will confirm that you are in the right place)
Stop drilling at 10 mm depth.
Put a 2mm nail (or the back end of the drill) into the hole. The black outer should now be locked to the blue inner and you should be able to twist off the cap as if it was unlocked.
Simples.
