Recommend both theHi looking for advice and maybe any pictures of best wind out awning side panels to attach to a Beach? Under £500. And also pop top roof waterproof cover? Thanks in advance
We don’t take the VW chairs with us so use those compartments for topper / awning kit / awning tie down kit and screen cover. But I believe the awning will fit in with a chair.Good afternoon,
I expect delivery of the Comforz Awning Kit hopefully before the weekend, I can't wait.
For all the user the users of the Comforz Awning Kit, where do you store it? Does it fit in the back door, between the chairs?
Regards,
Eberhard
We have the Comfortz Awning kit which we have had for 4 years. it’s been terrific. only problem we have found that when it rains we get loads of water puddle in the middle of our awning. With the awning kit fitted it’s not easy to get a good “tilt” so the water runs off. This year we bought a Fiammia rafter pro. It prevents the water from one large puddle to probably two smaller ones. It hasn’t rained yet so not sure how it’s going to be but it’s bound to be better than the gallons that would sag the roof without it.
We made our own from waterproof material, they valcro onto the wind out arms and peg down at the bottom. I seem to remember the material cost £20 on eBayHi looking for advice and maybe any pictures of best wind out awning side panels to attach to a Beach? Under £500. And also pop top roof waterproof cover? Thanks in advance
We've looked at these and wondered how quick they would be to set up.A faff to put up.
How does it rate compared to setting up your airbeam awning?
We can get our Vango Galli up in 20 minutes.
Thanks.That's really helpful.This is only the third time we have used it.
Unwind the awning as usual.
Insert the G3 support beams. They go at the extreme left and extreme right of the canopy.
Wind in the awning tight to clamp the support beams between the awning front and the casing on the van.
Hang the left and right panels, beading slides into the support beams.
Hang the front panel, beading slides into the awning front.
Join left panel to front panel with figure of eight. Same with right panel.
Tension left and right panels to van side with straps.
Adjust awning legs.
Peg out.
Probably 30 minutes.
You can also seal off the bottom of the van and rear wheel so the G3 can be heated. It is pretty much draft free.
You don’t want to be setting it up if you will be wanting to drive away.
The way I pack it, it is about half the bulk of out Vango Hexaway.
Note: there is absolutely no possibility of opening the driver’s door with the G3 in use, so if you haven’t swivelled the driver’s seat you can’t without partially dismantling the awning room.
It is just about big enough to set up a kitchen area and four to eat around the picnic table.
We were thinking of having something quick to erect for short stays. It doesn't look like there would be much of a time saving against the current awning we've got.
I wonder if the other manufacturer's awning panels are quicker to erect?
I‘ve bought 8 meters of a 220cm wide waterproof canvas for about 100€. I‘ve bought a new sewing machine for 350€. Some eyelets with washers and 3m of keder strip. So in total about 500€. I didn‘t know how to sew, watched a few youtube videos, sewing a tarp is pretty much just straight lines so very easy. I‘ve basically made my own cave, three panels that attach to the awning arm and/or poles, can be all closed off, very easy to put up or stow away between the chairs in the tailgate. If they get dirty i can chuck them in the w/m.We made our own from waterproof material, they valcro onto the wind out arms and peg down at the bottom. I seem to remember the material cost £20 on eBay
Good afternoon,
We got delivery of our new Comfortz Awning Kit yesterday. We tried it out straight away:
Good afternoon,That colour goes well with the van.
Our van will be the same colour when it arrives.
Is that the Mid grey or the Light grey colour Awning?
Thanks for the info.Good afternoon,
It is the "mid grey" colour. It turned out quite well. I believe the success of the awning is the good quality and to speed to put it up.
