MattBW
Here to help
I am embarrassed to say I've had the isotop for quite some time and was nervous about fitting it, however I finally got around to doing just that and filmed the experience for the club shop. This is just a basic post with my experiences and thoughts. The video will come soon. The ocean/se install may be slightly different.
Instructions
The instructions are awful, there is no other word for them. It feels like they've been converted via software. The result is weird instructions that are English words but not English sentences. I think they add to the intimidation and make it feel a lot harder than it is. The pictures are also too small and not very clear. That aside the install is actually quite easy and not as bad as it first appears. The T5/T6 beach version seem identical.
With help from club members I got a few hints and tips from Club members (especially Bob thanks)
Materials and Quality
The liner feels very nice, has a black outer side and a velvety inner fabric. It feels good quality but not too thick. The windows are much larger than the ones in the poptop making it easy to get ventilation and light when you need it.
Install
You get two wipes to clean the aluminium where you attach the hook and eye tape (like velcro), the first is a cleanser and the second appears to make the metal tacky for the tape to adhere better. This is really simple although I found the wipe was pretty destroyed by the time I had finished the entire coverage, two of each would be better Brandrup
Hook and Eye tape (similar to velcro)
You then apply the tape around the bottom of the van which is very easy and there is enough to cover the entire lower edge, with some spare left over for future use. Some thicker tape is applied at the back of the poptop upper edge and this too is easy to install albeit cramped.
Velcro attachment tabs
On the Beach 3x velcro tabs are screwed into the plastic roof at the front for the isotop to attach to. The instruction say not to use powered screwdriver and to do it by hand but to be frank I found this impossible. The self tappers didn't bite quite right and the angle was awkward to get enough pressure and speed at the same time. I used a small electric screwdriver cautiously and it went straight in. Important here not to over tightenI was pretty worried about the roof above but all seems fine.
The two rear velcro tabs are inserted up into the roof edges and held in place by friction. We used two laminated business cards to make this much easier. This is probably the fiddliest part of the install. We followed the instructions and found when we installed the fabric they are in the wrong place. After a little trial and error we pretty much came to the conclusion these aren't really needed. Although the video will show them being installed , I personally think you can probably miss them out on a beach if you wish.
Then it was just a case of hanging the fabric, fiddly but good. The resulting finish was very nice and has a cosy feel to it. It feels much higher quality than the canvas alone.
Using the isotop for Camping
We camped with it for a weekend recently, warm days and windy cool nights and found the whole feel of the poptop was much more cosy. It was much less drafty, the heat wasn't sucked through the canvas, and nice and dark, meaning we weren't woken at sun up.
In fact using the heater at night, the whole van felt warmer for longer, and the heat seemed to stay in the poptop too whereas normally we find it doesn't. In the morning the heat of the sun didn't make it uncomfortably hot either.
Very impressed, we see now why everyone loves the ISOTOP internal topper. I slept far better than normal when it it is damp and cool as it was that weekend.
Tips and Closing the Poptop.
I think a bellows bungee is a must for Isotop especially on a beach. It makes amount of material a little thicker and we can no longer tell if the roof is folding inward or outwards visually. There is more fabric up there so we have to be more careful when closing the roof to keep the fabric away from the clips and locks (not an issue on the ocean?). A bellows bungee is a cheap addition that takes away fear of damaging the canvas and mitigates not being able to see the roof inside.
Conclusion so far
A great product. Fit and forget. Makes the roof feel luxurious, fits beautifully, much warmer in the cold and cooler in the warm. Darker too. It has lovely big vents that can be opened too to let in light or air if you wish. Makes the roof in the California much more comfortable in all conditions, maybe it should come as standard?
Edit video added
Instructions
Install
Conclusion so far
Edit video added
