clarinetbcn
T5.1 Beach 140
I know the opposite is not possible, fitting 16" wheels (with winter tires for example) to original 17" steel spec van, because of the size of the brake discs, but will the 17" steels fit an original 16" spec? Are there any drawbacks? Will it still pass technical inspection (both 16" and 17" are included on the door sticker listing correct tire air pressure)? Will the ride be noticeably harsher because the shorter sidewall has less ability to absorb shocks? Is the overall diameter the same, re: speedometer, cruise control, parking sensor height, auto-leveling bi-xenon headlights, etc.? I like the look of the 17 inchers and think it's possible they will react with more precise handling on curvy mountain roads, and always use steel because I'm off road a lot.
