Cruise control
jts46
jts46
Derbyshire & Lot et Garonne
T5 SE 130
The cruise control on my 2006 california has an intermittent fault.
When i use the indicator stalk the cruise control will sometimes drop out, not every time, can someone explain how i get into the wiring of the indicator stalk and access wiring behind steering wheel cowling
Remove the trim around the steering wheel column. And if necessary the under trim of the dashboard.
But the problem might as well be the stalk itself. This is 1 unit with the 2 stalks. Then you need to remove the airbag and steering wheel.
thanks for the reply do you happen to know the part number for the stalk?
This might help.
Bit left field but do you have your foot or feet near the clutch or brake pedals at the time. Just a thought as I often have my foot hovering over the pedal when intending to to change lanes etc. and if the pedal switch is sensitive ??
Thanks but foot no were near pedals
