DrJuanKerr
I've created a little 30 second survey on SurveyMonkey. The in-site survey creator is too "cumbersome"
I'd appreciate your responses. Once I have enough I'll make the results available here
Survey Link
EDIT: As of 04/08/19 31/07/19 I have 74 responses
1. Which type of topper have you purchased?
Answered: 72 Skipped: 2
Internal Topper:33.33% 24
External Topper:48.61% 35
Both:18.06% 13
TOTAL 72
2. If you bought an internal topper which of the following applies?
Answered: 66 Skipped: 8
It was initially purchased, installed and there it remains to this day: 56.06% 37
It was initially purchased, installed, removed and then kept elsewhere: 4.55% 3
It was initially purchased, installed, removed and then sold [up for sale]:1.52% 1
Not Applicable:37.88% 25
TOTAL 66
3. If you bought an internal topper and had to replace it, how likely would you be to get another one?
Answered: 67 Skipped: 7
Definitely would: 46.27% 31
Probably would: 5.97% 4
Probably would not: 1.49% 1
Definitely would not: 1.49% 1
Not Applicable: 44.78% 30
TOTAL 67
4. If you bought an external topper which of the following applies?
It was initially purchased and is constantly used when the need arises: 51.39% 37
It was initially purchased, used a small handful of times and then kept elsewhere: 16.67% 12
It was initially purchased, used a small handful of times and then sold [up for sale]: 5.56% 4
Not Applicable: 26.39% 19
TOTAL 72
5. If you bought an external topper and had to replace it, how likely would you be to get another one?
Definitely would: 29.17% 21
Probably would: 18.06% 13
Probably would not: 13.89% 10
Definitely would not: 9.72% 7
Not Applicable: 29.17% 21
TOTAL 72
6. If you bought both internal and external topper, which would you say gave the most value for money relative to usage?
Internal: 26.39% 19
External: 8.33% 6
Neither: 1.39% 1
Not Applicable. I haven't bought both types: 63.89% 46
TOTAL 72
Survey Link
Both:18.06% 13
TOTAL 72
TOTAL 66
TOTAL 67
TOTAL 72
TOTAL 72
Internal: 26.39% 19
External: 8.33% 6
Neither: 1.39% 1
TOTAL 72
