Good afternoon,
4x new Michelin CrossClimate+ tyres.
Regards,
Eberhard
Good evening,
Yes, I am glad that I got them.
They are not louder than the Goodyear, drive quality is the same, they are good in the wet (on the way to Achill Island we had more than our fair share of rain), front tyre slip has not happened (yet). If I use more diesel is to early to tell.
I also expect better traction on unpaved roads. I expect those tyres will do well during out Europe trip in July.
Regards,
Eberhard
Then explain me this picture. An "empty" California aligned up to an empty Multivan (500 kg difference).But your idea that the rear end is lower because of the load is Incorrect. If you study the VW technical drawings for the T5/6 you would see that in fact the Wheel arch is cut higher at the Front than the Rear.
Measure the Distance from the horizontal body line to the top of the wheel arch. That distance is cams less at the Front compared to the Rear.
When loaded and driven on rough roads the Rear wheels can ride up into the wheel arches. Similarity on the Front if driving straight ahead, But if turning the Front wheels protrude outside the wheel arch and could foul the arch and cause damage thus the Front wheel arch is cut higher to enable the Front wheels to maintain this upward movement without damage.
Many, many vehicles have this same arrangement.
Lowering the front or raising the Rear to even out this difference means the vehicle will be Nose down instead of parallel to the road surface.
An absolute necessity for little bosses.
Looks like they are pleased to see each other in that photo ...Then explain me this picture. An "empty" California aligned up to an empty Multivan (500 kg difference).View attachment 46060
Ok, it is a T6 vs. T5.1, but they both share the same platform: T5 from 2003).
I got t6 transporter version rather than Cali specific but the little plastic hooks at the bottom don't fit onto the plastic of the seat - just a smidgen to short....did I buy the wrong ones??I got them from e-bay. They are produced by Inka and I am very happy with the quality. I bought the generic Transporter version for the drivers side as its a tenner less than the California labelled version. There is no choice for the passenger side. Some of the e-bay photographs suggest that California versions are grey but they are all black.
Pull them a bit harder!!I got t6 transporter version rather than Cali specific but the little plastic hooks at the bottom don't fit onto the plastic of the seat - just a smidgen to short....did I buy the wrong ones??![]()
Sent from my Pixel 2 using Tapatalk
I will let me other half do that - I didn't want to cause any damage!Pull them a bit harder!!
Not tried it but other posts about it say yes they do still swivel.Will the seat still swivel ?
