I think the theory is quite straightforward; it needs to cycle more often to keep the temperature at a higher setting.
That’s what I said..No the reverse - freezing outside, heater set on high it will run constantly
Warm outside, heater on low, heater starts up every half hour runs for a couple of minutes, turns off etc
As its the start up that drains the battery, the first scenario may use less battery power in a night than second.
No it isn't,That’s what I said..
The LA80 is actually 75ah see attached.So, are these 2 Batteries the same, just Marketing and Price Difference?
In fact they both say Battery Capacity 80 amps but the LA80 also says Battery Capacity at 5 hrs is 75 amps.The LA80 is actually 75ah see attached.
I think you're right. Leisure batteries are designed for lower discharge currents over longer times to a deeper discharge level, compared to a 'car' battery, which is designed for high current discharge but kept relatively fully charged. They have the same Ah rating but probably have different plate thickness as you said. I guess with start / stop technology, the 'car' battery is getting more discharge / charge cycles than they used to.So I presume they might be different internally, eg: thicker plates on the LA80? allowing a deeper charge profile?
So why the price difference - why not buy the cheaper one?F21 and LA80 are the same battery, yes. Sold under different label...I have used both F21 and LA80 in my California...and my friends California’s...
So which one should I go for?F21 and LA80 are the same battery, yes. Sold under different label...I have used both F21 and LA80 in my California...and my friends California’s...
Some very clever chaps in a VW specialist in Amesbury reinstalled my Kenwood system (after two cock-ups). and put in a three-way switch in the glovebox (car battery/off/leisure batteries). Whilst I'm getting paranoid now about the leisure batteries running low, I have absolutely no fears now about the car battery running down!Can't answer your question but....how do you switch the radio to leisure battery?
Thanks for that. I'm wondering if maybe the percentage indicator is at fault; it stayed on around 90% for several hours, while the voltage went right down to just under 9! Either way, do you agree that after 2.5 days with only a fairly high-temperature-setting fridge and the occasional radio, a voltage of less than 9v doesn't look right, and I maybe need the batteries tested/replaced? I think they're still under guarantee. Thanks for your help.I think you've discharged your batteries too far. I wouldn't let them go much below 11.5V for long. Running the engine wont recharge them fully unless you're running for hours, the % indication is probably only a battery terminal voltage which rises on charging and then drops when settled, you've seen the battery % before it's drop and not much charge has gone in, I think. I'd get them onto mains hookup for 24 hours and see.
Yes, voltage will drop as the battery is discharged.
edit - copied from the net... View attachment 45821
I would say that 9V after 2.5 days light load would be indicating low capacity, but that's assuming that you had a good 100% full charge at the start, which I would recommend using a mains hook-up for 24 hours prior to setting off.Thanks for that. I'm wondering if maybe the percentage indicator is at fault; it stayed on around 90% for several hours, while the voltage went right down to just under 9! Either way, do you agree that after 2.5 days with only a fairly high-temperature-setting fridge and the occasional radio, a voltage of less than 9v doesn't look right, and I maybe need the batteries tested/replaced? I think they're still under guarantee. Thanks for your help.
Lots of interesting things there, and it's beginning to make a bit of sense to a real novice! The current shows around 0.2 amps with just the radio going, and 3.5 when the fridge kicks in. A little more with the lights. So such a rapid reduction in the voltage seems a lot. I always assumed the standard setup on a Cali was the two batteries linked, so your estimate of 4-5 days would seem reasonable to me. I've checked my old receipts, and I rather think only 1 battery was changed 3 years ago (they forgot to look at the second one, so I had to take it back!), which means the other is 11 years old! On balance, I think I'll take it in and get the whole thing checked over. The wiring for the new flexible radio connection might well be affecting things, but I think that from now on I'll keep an eye on the voltage rather than the capacity. I admit that I also tend to rely on a long journey to charge up the batteries, but - from what you and one or two others have suggested - a mains charge for a day before the journey is pretty much essential. Thanks so much for the help. I have a lot to learn!I would say that 9V after 2.5 days light load would be indicating low capacity, but that's assuming that you had a good 100% full charge at the start, which I would recommend using a mains hook-up for 24 hours prior to setting off.
Assuming 1x 75Ah battery, a load of 7.5A would take a fully charged battery down to around 10.5V in 10 hours, 20 hours for 2x batteries...
Does your display show the current when radio on, fridge running, lights, etc? A I reckon you'd be about 2-4A averaged out which should last 2-3 days continuously on with one battery, 5 days with 2. Not sure what setup you have.
As for the percentage display, I don't know. Maybe some other members here can help. I would think there is a voltage and current measurement calculation done within the control panel to give a 'rough' capacity indication, possibly only based on voltage... Something else to consider is with the wiring mods done, with the control panel current measurement using perhaps the ground return from the 'leisure loads' and you've switched a new feed path to your radio using its chassis ground? Wouldn't be a problem to work, just may not show up in the panel display.
