MartG
And the two halfs separate too, just need to get the angle right, bit of a faff to get back together...On the new versions the handles detach.
I found that too, may be a case of just getting used to it.And the two halfs separate too, just need to get the angle right, bit of a faff to get back together...
Thx Elly, but I'm afraid Matt has very dated footage in the meantime and should definitely cross that old Channel again, to shoot the latest mods for his new channel.Will be interesting. He’s very inventive.
Last night we had Scottish Salmon fillets, tonight Chicken & chipsI absolutely love my large ridge monkey. If we are making mulitpul dishes they can be spread between the sections (I don’t eat meat but love fish) and the Spanish omelette has become a staple. Food pics attached View attachment 45078View attachment 45079View attachment 45080View attachment 45081View attachment 45082
It looks a bit 2 dimensional!Perfecting bread baking in the Ridge Monkey. On an electric stove for now, will try on gas hob as well.
DefinitelyIt looks a bit 2 dimensional!![]()
must be baked in closed Ridgemonkey. But it's nice and fluffy inside Perfecting bread baking in the Ridge Monkey. On an electric stove for now, will try on gas hob as well.
Looks great! I make all our bread at home and would love to have a go in our Ridgemonkey - any chance of the recipe and how you do it with the Ridgemonkey?
Cheers
ian
Hey thanks for the reply! I think we have a similar bread making method - kneeding is much over rated! It’s great to know that bread making is possible in the Rm and yes it would be interesting to know how you get on in the Cali.So I tried the same recipe I use at home.
Mix 300g of warm water with a teaspoon of salt and a small amount of yeast (maybe 2g - I buy yeast in 42g pack and make around 30 small balls which I keep in the freezer).
Add 430g of flour (I use 300g of white flour and the rest any other flour). Mix well with a fork, since the dough is rather wet. Then cover airtight (lid or a plastic bag) and let it rest for 8-16h.
Then scoop the dough onto a work surface with some flour and - no kneading! - just fold the dough inside from all four sides and turn it over. Put the dough back in the bowl into which you added a spoon of oil. Let it rest covered for another 1-2h.
Now as I was baking the bread in Ridgemonkey, I cut the dough into 5 pieces (4 would be better) and put them in separate bowls. Then I heated the Ridgemonkey thoroughly, put the dough inside and it took about 15 min to bake each bun on medium heat - turning it regularly so it didn't burn.
It sound complicated, but it's really simple, just takes a lot of time.
When I'm baking bread in the oven - I put a cast iron pan in the oven and heat it to 230 C. When hot, I flop the dough into the pan, and bake it covered for 30 minutes, then I open the lid and let it bake for another 5 min.
If you're interested - I can try half the ingredients and try baking it in the Cali - I can let you know of the result.![]()
