5i1ver8ack
- Messages
- 446
- Vehicle
- T6 Ocean 204 4Motion
Thank you. If I have to, I'll give it a go.
Your vehicle is under Warranty. Try to lower the roof in the morning. If it fails -Thank you. If I have to, I'll give it a go.
Flick out the control panel with a butter knife or a spoon.
Then you can access the pump.
There is a slotted screw on the pump that you can unwind the roof
with.
It releases the oil pressure.
Good luck.
I had exactly the same issue it was left side, to correct for now when opening let it lower and then turn ignition on and press to open again and it will stay open then....vw fixed mine, it took a week but had no issues since. Mine is also brand new September....Really Useful hints and comments - thank you everyone - will give them a try.
Possibly.Back at the campsite Roof up - worked perfectly
A one off glitch?
No Problem. Just enjoy.Thank you, Mr Gas.![]()
Sorry for taking. A little while to reply. Away in my California, the dealer recalled the van for work to be done on the roof. I asked what was needed, they said some protective tape, which seemed a bit vague, but I didn’t worry too much until I saw the roof come down at an angle. More than 5cm difference. Probably 8 to 10? Apparently all T6 are being checked when they come in for a service.Hi if it’s less than 5cm difference between each side then it’s all ok and within specjust keep an eye on the roof as it’s coming down. What work did you have done ?
