OK, the MFD fuel economy measurement, and here I’m talking about the Memory 2 Average MPG, is presumed to be over optimistic compared to a Fuel Tank brim to brim calculation. But is it?
A Fuel Tank brim to brim calculation will not take account of the fuel used to run the Diesel Coolant Heater, in winter, and the Diesel Parking Heater although this might be a small component. However, it also doesn’t take account of the fuel used in the DPF regeneration cycle. All these additional factors will decrease the calculated fuel economy figure ( MPG ).
Now, the MFD calculated MPG is often greater than the Brim to Brim calculation, meaning it seems to be over optimistic. But is it?
I presume the vehicle doesn’t measure the fuel consumption directly but is calculated from the Fuel Rail Pressure and the time each Injector is functioning and data on the Injector performance at certain pressures.
Now, if the MFD Fuel Consumption is based on this assumption and Injector function on the Power Stroke only and NOT Injector function on the Exhaust stroke during DPF Regeneration then it’s MPG calculation might be much more accurate than we believe as it is purely based on Fuel used / Miles covered, disregarding ALL fuel used for other purposes ie: DPF Regeneration/Coolant and Parking Heater.
I don’t know if my reasoning is correct, but does anyone else have any thoughts.
