Control panel is showing -0.6A, higher than I would have thought for one tiny blue led.I’ve been looking at doing similar but decided against it as I think the USB sockets will be drawing current even when not in use. I’d be interested to know if your control panel is showing anything.
Agree, the led will draw some current and the circuit that drops the 12v to the 5v supply is probably drawing more and as you say likely to put a drain on the battery.If that blue led is staying on the whole time even without something plugged in chances are it will drain the batteries when your Cali sits unused long time...
Am I right in assuming if you switch this off it will draw no current? Or do you withdraw it from 12v socket?The USB socket is running more than just the Blue LED.
That is why I plugged in one of these.
I leave USB sockets in the dash lighter socket permanently. With 2 x 100 Watt panels on the roof and the Cali parked on our driveway which is to the south of our house, I have no concerns even during dull winter days.I’ve been looking at doing similar but decided against it as I think the USB sockets will be drawing current even when not in use. I’d be interested to know if your control panel is showing anything.
Has a switch so you can leave it plugged in the socket. Incorporates a digital voltmeter display when switched On.Am I right in assuming if you switch this off it will draw no current? Or do you withdraw it from 12v socket?
Not just the led that draws current. All unswitched USB chargers draw current all the time.Why waste 5 minutes if you can have the same result in 1 second?
These flush-fit usb chargers cost less then 10 quid, stick out only a few millimeters, and don't have a "battery draining" led light. Mine is an Aukey but there are also others brands on Amazon.
Probably, but I don't see that as a problem when the charger runs off the leasure battery. Anyway, not having a led must help a bit. The main reason for my post is to illustrate that you don't need to dismantle the socket unit to install a usb charger in your Cali.Not just the led that draws current. All unswitched USB chargers draw current all the time.
5G should be fun then!I've found the same with those plug in usb devices, they knock my DAB off the air at times, since I did Amateur radio I realised they are often badly designed in china and emit radio waves.
Sadly they often build them to be compliant up until testing, then remove the parts that stop the interference after certification to save money but of course they are then non-compliant.
Sadly I'm yet to find one that doesn't cause some kind of interference as everything is made in China now.
When I worked for BT Ofcom definitely kept an eye on us, but that was a long time ago!I can't imagine commercial companies would get away with it, but you never know these days, Ofcom don't seem to step in like they used to![]()
