I have made a 5 metre extension cable out of 6mm^2 cable. Links to leisure battery via hard wired Anderson connector.
Trying to work out best way of getting it out of van as gets crimped in sliding door. Don’t want to destroy either the cable or damage van!
I believe the Leisure Battery and electrics are under the same seat. Drivers seat LHD or Passenger Seat RHD.Under the (for left hand driven cars) driver's seat (left seat) there is a rubber hose where cables go through.
You might try to look for that. I used that exit to get the cable through for the towbar.
If you manage to get a very good waterproof connector, you might pull it up and down with little effort and water intrusion.
Where are British leisure batteries placed? Under the passenger (left) seat?
If you look onder the seat left and right (put them in most front position), lift up the carpet if there is a cable going underneath it. It might show a rubber pad with or without cable going through to the outside.
When you open the tailgate you will see a loom on the left hand side. You can run a fixed cable from the leisure battery, under the trim to this loom, then out through a small incision in the loom to the awning casing.
Surely the purpose of using 6mm cable is that voltage drop will not be an issue.Hi @Amarillo -- trouble with this is that then the cable starts becoming quite long -- and would need to start thinking about voltage drops again. The purpose of this is to relocate the fridge to an awning. I tried seeing if the supplied Dometic cable would go through door without pinching but it also gets pinched (that's quite a bit thinner than my 6mm^2 exension too).
I bought 10 metres of 4mm cable, and have no concerns.
On our LHD 6.1, that is certainly the case!I believe the Leisure Battery and electrics are under the same seat. Drivers seat LHD or Passenger Seat RHD.
