V
vwsween
I have a 2006 SE which I believe should have 1 leisure battery under rh front seat and as an option, a second battery under the wardrobe. My recently purchased van has no battery under the seat but does have one under the wardrobe. There is wiring for battery under the seat and the battery under the wardrobe has no markings to identify it.
I presume that ideally there should be 2 batteries but I need help to know what type/size/make they should be.
I also suspect that the 1 battery I do have is old and not having decent capacity. My reasons being, when setting off on a 3 hour journey I turned the fridge box on set at 3 degrees. Initial reading from battery via the central control panel was battery charge was 13.2v and draw was 3.2a. After 3 hour drive the battery was down to 12.5v. Then after another 3 hours the reading was 12.1v and supposedly down to 30% of capacity.
So in summary, I think the battery I have is old and needs to be replaced. In addition I guess I ought to have 2 batteries but I don't know what they should be.
Any advice would be appreciated.
Brian
Brian
