Use milton steriliser
How old is it. Mines a 2016 and I just used mine normally. If your boiling the water for a coffee anyway you will survive. You could fill it half way. Drive about a bit and dump it. Depends on the age I suppose. Otherwise Milton
Mine was 2nd hand too. Just give it a rinse. Make sure you use your own hosepipe at camp sites to fill it as people often rinse out their crap buckets with them when they can't find the proper disposal point. That's a bigger worry. But that's caravanners for youIt’s a 2012.
We will only be using the water for hot drinks and washing anyway so, good point
Oh Poo poo. That's bloody horribleMine was 2nd hand too. Just give it a rinse. Make sure you use your own hosepipe at camp sites to fill it as people often rinse out their crap buckets with them when they can't find the proper disposal point. That's a bigger worry. But that's caravanners for you
Anyone had any problems using Milton, read a previous comment re corrosion to metal. As far as I can see, it’s all plastic so a couple of tablets popped in then washed down with water should be fine, just a little hesitant.
Except for the water sensor?it’s all plastic!
). Not to change the subject but has anyone suffered similar and found something that brings smell back?
