flying banana
T6 Ocean 204ps manual
Cheers. Assume they don't foul the jack points. Look goodNo, Vanstyle. Half the price of OEM. Took me hours to fit though, but seem to be good quality. I'll report properly on quality in 10 years time.
Good question. I've just popped out to check and it looks OK.Assume they don't foul the jack points
be good to know it fits still. I've heard of some side bars getting in the wayGood question. I've just popped out to check and it looks OK.
TBH I've always used a trolley jack to change wheels, fitting under the suspension arms. I suppose I ought to try the standard scissors jack just in case I have a flat on the road.
Thanks for your comment f-b, I can confirm that the sidebars do get in the way of the standard jack. Fortunately, the bars are only attached with two bolts, so I've popped a 14mm spanner into the toolkit, just in case.be good to know it fits still. I've heard of some side bars getting in the way
Sounds like a top tip thereThanks for your comment f-b, I can confirm that the sidebars do get in the way of the standard jack. Fortunately, the bars are only attached with two bolts, so I've popped a 14mm spanner into the toolkit, just in case.
So......That will be a little extra fun when you change your wheel in the rain/snow!Thanks for your comment f-b, I can confirm that the sidebars do get in the way of the standard jack. Fortunately, the bars are only attached with two bolts, so I've popped a 14mm spanner into the toolkit, just in case.
Who was supplier? And did you have them fitted or did you DIY?
Impressive! Thanks for info.Seatskinz. Fitted myself took about 3-4 hours to do.
Hi need one of those fridge things. Please advise of contact details for one please.Amersfoort and Campercentrum was a lovely stop on our way back today.
Got a new tent/awning lantern and that plastic thing for the fridge. Also the first customisation was made by them, holder for the fire extinguisher. While the shopping spree lasted we also got a Thule sun blocker. Good stuff!
This is the one
VWCampershop for Brandrup, Volkswagen and Westfalia accessoires
Camper shop for all Brandrup, Volkswagen California, Multivan, Westfalia, Fiat and Mercedes Marco Polo accessories.www.vwcampershop.nl
Had a couple of bits wrapped... excuse the dirty Denzil. Also had the lights smoked.
View attachment 43845View attachment 43846
Just a heads up re the mirrors, I’m sure someone recently reported that following the wrapping process their navigation and dab stopped working. This was due to the aerial and GPS receivers being contained in the mirrors, the wrap they used interfered with the signal.
Worth checking if you have either.
I think that the problem ended with the wires not being connectedJust a heads up re the mirrors, I’m sure someone recently reported that following the wrapping process their navigation and dab stopped working. This was due to the aerial and GPS receivers being contained in the mirrors, the wrap they used interfered with the signal.
