Safe: Replacement lock
willwander
willwander
Yorkshire
No keys for the Safe. Had to drill out the lock. It was empty :(
Is it possible to buy a replacement lock?
43292
Do you know if there is an OEM part number?
Finding one just the right size on eBay might be tricky.
According to the Parts Catalogue there are no separate parts. It is sold as one unit. Parts 17,18 &19 Although there is a link to another German Company.
Thanks Loz and Willwander, I think I'll drill it out this weekend and then check out the unico website - they look just right.
I noticed Unico do a version of the cam lock with a combination lock, might be a better option than another key?
Did you order one of these? I drilled out the lock (which was worryingly easy to do...); the only issue is the lock I've removed has a smaller body than any of the replacement ones at Unico (or EBay). So it might be a case of making the hole in the safe door bigger with a dremel, or seeing if I can source a small bodied lock. Would be interested to hear of anyone else's experience.
