L
Legin
Guest User
Due to popular request here are the details for a stop start module installation. The basic function of this module is it presses the button on your behalf. It effectively remembers the last setting. It is in no way invasive to the ECU. I have fitted to my T6 and it works great and actually transferred it from my passat to the T6
Suggest buying from this link and he will send you fitting details which are quite straightforward. there are two types so you advise him its a t6 and he will send the correct one - the plus version.
https://www.ebay.co.uk/itm/NEW-Star...h=item4b0dae5f2d:g:ArAAAOSwzRlaGn7O:rk:2:pf:0
Some photos of the install which is what he will send - takes about 30 mins. Just make sure you look very closely at which wire as some cross in the photos. Cut back the loom tape to get good access. Three red scotch lok required.
