Remove Gamma 4 head unit
berg86
berg86
Sweden
Grand California 600
Hi!
Searched and cannot find the answer to this..
I have the Gamma 4 head unit with cd changer, I can not seem to find any slot in this for removal tools?!
Does anyone know how to remove this unit?
And is there an ISO connection on the back or will I need to re-route cables?
Thanks in advance.
Cheers
Hi!
Thanks in advance.
Cheers
Hey. Any chance of a photo of your setup? I think I know how to remove the head unit as I removed a similar one from our SEAT Alhambra. The wiring for the unit should be standardised but if you’re replacing the unit with a modern aftermarket one you may need to modify it slightly to maintain a permanent supply for the memory.
Hi!
Thanks in advance.
Cheers
You can make your own tools by cutting a credit card (use your wifes )
Ha ha. I doubt you’d be popular after that. Those are exactly the keys I have and what I was going to suggest you look for. You’re upgrading?
I have seen the info for the other Gamma unit, however this one is different.
Cannot see any key slots for this one, but I am sure there must be some way?
Thanks again.
After doing some more inspection with a good flashlight I found the slots after all.
Hopefully it's the same keys as the other units.
Thanks again.
