JezD
Hi all, I’m after a bit of advice on the power supply to the internal, non door activated, lighting in my 2017 Beach.
The story behind this question is really convoluted but will be subject of a review of the appalling service I’ve received at a VW main dealer. I won’t bore you with it here but would appreciate it if anyone could tell me this:
Should the internal, non door activated, lights and electrics work if the leisure battery is completely flat but the ignition is on?
In other words, are the leisure battery controlled electrics also hooked up to the main battery so they can run off that if there’s no juice in the leisure battery?
In other, other words, is there a plausible reason why the leisure battery electrics should work when the ignition is on, but not when it’s off?
