bvddobb
The coolant fluid degrades over time.One could argue so is the air con?
I beg to differ I’m afraid. It needs regular lubrication which is carried in the Refrigerant used. Also the system is disinfected which can be important for passengers health, especially if the system/vehicle is not used regularly.One could argue so is the air con?
I use it virtually everyday, although retired. Park anywhere that has a minimum height of 2m or more.Hi Welsh Gas that’s impressive mileage and similar to my mileage that I will be doing in my Cali as my daily driver .
What’s your experience been driving the Cali that much and what if any problems have you encountered?
But you do miss out on the 2 yr warranty VW give for the parts and fitting if you don't use a Dealership. Maybe not something to worry about with some simple service items but Cambelt etc: I would use a Dealership for my peace of mind.All of this of course depends on if you are mechanically minded and can turn your hand to some of the work yourself. For someone with a reasonable mechanical knowledge and a decent set of tools changing brake discs and pads is not rocket science. And of coarse you don’t have to buy Genuine VW branded parts. Aftermarket parts are available at under half the price. And I don’t mean rubbish you can get EBC discs and pads which is probably the ones VW use anyway. But like I say if you don’t have the skill, knowledge and tools go to a VW main dealer.
Thank you some good adviceI use it virtually everyday, although retired. Park anywhere that has a minimum height of 2m or more.
Parking in car parks I tend to park with NS next to a Vehicles NS so the vehicles passenger cannot get in without moving their vehicle. Avoids car park dings.
Problems, none, just an annual service , normally every 20,000 miles or just under.
I run All Season tyres once the original had worn down.
If you have a spare wheel then either chain the spare or fit a vehicle Spare Safe - See Forum Shop.
Depending how long your commute is try to get some long trips in to avoid DPF problems.
If you have the Diesel Parking Heater then fire it up at least monthly for an hour or so.
Don’t forget to plug into the Mains for at least 12 hrs monthly to keep the Leisure Batteries in good condition.
And enjoy it as I do.
Others have posted about. I managed it in the T6 LWB Panel van they gave me and that was a 102 Manual.WG - good feedback especially on tyre choice.
On a slightly different tack I see your comment on possible FWD wheel spin, which I have seen mentioned many times on this forum. Interestingly, in my 6+ years of Cali (180 FWD) ownership, I can't remember spinning the front wheels a single time?
There are many different types of EBC pads. But you can get Brembo replacements at Half the cost of OEM.EBC pads are not oem btw and the petrol heads on here like me will confirm they are pretty poor performing pads, the discs are ok. I do agree however there are some good aftermarket pads and discs available for good prices.
I know I have tried most of them. Cheap for a reason.There are many different types of EBC pads. But you can get Brembo replacements at Half the cost of OEM.
But of coarse I agree that’s why in our country we still have the choice if you want to repair things yourself you are free to do so. If the motor repair industry goes the same way as the building industry in a few years we maybe won’t have the choice but to take it in to the main dealer and spend Many many hundreds of £ every time something goes wrong. At the moment you are free to choose.
Even factory trained technicians get it wrong sometimes as I’ve found out at my cost.
You could practice on someone else´s car first before you doBut if I have an accident because of faulty breaks and something bad happens, if I did it myself I will never forgive me.
Good afternoon,
Yes, I agree that mechanics in dealers repair shops make mistakes. But if I have an accident because of faulty breaks and something bad happens, if I did it myself I will never forgive me. Nobody can accuse me of neglect if I give the van to an official dealer to get the breaks repaired. If they mad the mistake, still the accident might happen, but it is their responsibility, conscience and insurance.
Regards,
Eberhard
your own Eberhard.![]()
