Nothing - the space you see is for housing the detachable tow ball if you have one.
Cannot see your locking wheel nut whotsit??
I do have a locking wheel nut. Should it live in the toolkit? What hole should it go in?
Sorry...The key thingy - not sure which hole but I have always found them in the tool kit somewhere.
If you have the Can of Sealant - the idea is to Jack the vehicle up so that the wheel spins free. Inject the sealant, spin the wheel coat the inside and then pump up before lowering it back down.You can see it in @willwander pic at about 11 o’clock from the towing eye. Top tip is to remove the stop in the left sliding seat rail so you can slide the seat forwards to easily access the wheel kit through the side door rather than having to empty your boot on the roadside and crawl inside.
I looked at mine the other day.... no spare wheel yet was surprised to see a jack. Not sure what I’m supposed to do after I’ve jacked it up!
Thanks ... I must get a spare before that happens.If you have the Can of Sealant - the idea is to Jack the vehicle up so that the wheel spins free. Inject the sealant, spin the wheel coat the inside and then pump up before lowering it back down.
Too right - don't whatever you do rely on the tyre sealant cr@p. Always have a proper spare.
Many on here will be wondering if that £30 spare wheel you bought was the one nicked from under their van!Totally agree, the sealant is not appropriate for a campervan where you could be away on holiday or off the beaten track. A spare is a must have, we purchased the kit from the shop and got a spare wheel off ebay for £30
Ah!.... the anti hernia kit. I hadn't realised and I have only had ours since 2012Pushed into the end of the wheel brace you´ll find a
double ended screwdriver and the end of the wheel brace
is meant to be pushed into the hole on the spare wheel carrier
to help lowering and raising the spare wheel.
Just in case you were wondering![]()
As soon as I saw the original post, I just knew you would be there to reply, Granny Jen!So that's what the inside of one looks like!![]()
