Andrew Dyer
Andrew Dyer
Hi,
I have been lurking around these forums since we bought a 2009 California SE in May this year, and have found loads useful information- so thank you!
Having plucked up the courage to post I am hoping someone can baseline my expectations of Cali leisure battery life.
At the time of purchase the dealer replaced both leisure batteries, because they were the originals and they were knackered. They apparently used ones from VW, due to the sizes required. However, with the new batteries in I am surprised at the rate they discharge when there is no indicated draw from the head unit. I have only been switching it on to capture the data whilst the van is parked on my drive.
I have read the manual, and it says to take out the fuses for the water pump and the roof to prevent deep discharge.. which would be a bit of a pain.. but are these likely the cause? I have used the EHU to give them a good long charge 8-12 hours, in 2 sessions.
I've attached the figures:
Having plucked up the courage to post I am hoping someone can baseline my expectations of Cali leisure battery life. At the time of purchase the dealer replaced both leisure batteries, because they were the originals and they were knackered. They apparently used ones from VW, due to the sizes required. However, with the new batteries in I am surprised at the rate they discharge when there is no indicated draw from the head unit. I have only been switching it on to capture the data whilst the van is parked on my drive.
