Door mirror aerials
briwy
briwy
Matlock & Pyrenees
T5 SE 180
Does anybody know which aerials are on which side of the van please with the RNS 510 with DAB.
I'm fitting a new drivers side door mirror and have disconnected the aerial module. All seem to be working OK on the RNS as I have a separate aerial for the GPS on the dash so I assume the passenger side aerials are for the DAB and FM?
I'm hoping this is the case as to get the aerial wiring rhtough into the new mirror assembly it going to mean splitting the leads and resoldering the plugs back on. Not a big deal but if it's not necessary then it'll save a bit of time.
looks like there are aerials both sides, DAB possibly in the drivers mirror
found this
https://www.vwt4forum.co.uk/showthread.php?t=167158
also this from T6 forum but may be the same as T5.1
N/S mirror houses AM/FM combo + optional GSM
O/S mirror houses FM + DAB + optional GPS
Black = DAB
Double white = 1 x AM & FM + a second FM
Blue = GPS
Yellow = USB
found this
Black = DAB
Blue = GPS
Yellow = USB
Thanks Carl. That makes sense although dab is still working on the radio with this offside stuff disconnected. Not sure what the usb stuff is about.
if you are fitting a genuine mirror then you can roll the aerial up and it will feed through the stem. No need to cut. However, I fitted power fold mirrors to my T5.1 - non-genuine - and I did have to cut the cable before it would thread through.
Parts Diagram and Part Numbers.
http://www.oemepc.com/vw/part_singl.../035/subcategory/35010/part_id/3700585/lang/e
Thanks for the link WG but Norton AV is blocking it. Says there is a problem with it.
Can’t help further I’m afraid. Don’t use Microsoft products and certainly not Norton.
reserves
Taff7996
8K
CampervanTime
CampervanTime
R
5K
Art Vandelay
Art Vandelay
