Max-Felix
As others have said the issue is two things - not pulling the lever hard enough (lift the lever and slide your hand in more so not just your fingertips pulling) and sitting on the front of the seat - as you pull against the seat with your legs and grip the floor with your feet the tendency is to tip forward slightly and the seat does the same, if you do this the rear of the seat comes up slightly and drags on the ratchet. Sit down plumb so your weight is back as you pull forward.
Probably best not to lube anything, certainly not with a wet lube - it will just attract gunk and grot and potentially make things worse down the line.
