sidepod
- Messages
- 7,573
- Vehicle
- T4 PopTop
So I’ve been studying the tech manual with regards to front end setup.
For reasons unknown I’m running an asymmetrical front end! Hardly ideal so it needs rectified ASAP.
Interestingly the 111kw (150hp) runs more negative camber (-1 deg 40”) than the lesser power models for a ride height of 257mm (measured at front damper bolt centres)
Has anyone had a full 4 wheel alignment done? It would be interesting to see what settings were used.
this is a technical thread, sidepod would be more interested knowing whether you toe in or out!!
