L
lewisnoble
- Messages
- 119
We have just returned from 2 weeks in Shetland - great place - met another California with gas regulator issues - hope you got sorted out if you are reading this.
Our table leg also fell apart, may be useful to recount how I fixed it.
Around 3 years ago, the sliding part of the leg fell out, the plastic gizmo locating the slider in the fixed part sprung out, springs disappeared . . . . We were wildcamping somewhere, so I repaired myself. Replaced the two missing springs with springs from retractable ball-point pens, stuck into their holes with a sticky dot from stationers.
This worked fine until our Shetland trip - I had not realised how crucial the grub screw in the side of the fixed part was, it prevents the sliding part slipping out altogether. So the grub screw is just as important as the springs.
It is a tiny grub screw, very small Hx key needed. No idea if available on its own from VW - I doubt it!! Nothing in my cycle spares that would fit, but I discovered that the brass terminal screw from a 13 amp plug fits OK - slightly too large, but beds in well, and can be removed with electrical screwdriver if need be, no need for a tiny Hx key. Works fine now ! though we still check the security of the leg very carefully before putting food down . . . .
Lewis - Sheffield
Lewis - Sheffield
