californiadreaming
Hi all,
Long time members/rare posters here. We thought we should probably share our experience of running out of diesel on the French Autoroute last week, as it may help someone else out who finds themselves in the same position and there doesn't seem to be a massive amount of info out there......
Long story short, we were driving from Annecy on the Autoroute in our '62 reg 180DSG Cali last week, the van ran out of diesel (despite the trip computer showing an estimated "Range" of 30 miles). Obviously the engine management light (the coil) came on, the steering became very heavy and the brakes became "spongy".
We were fortunate enough to be on the exit slip road and were able to coast into the filling station and fill up, with great relief. However - and I guess this is the major learning point for us - post 2009 T5's do not self prime. The vehicle will not start no matter how much you crank it, without the use of a laptop and VCDS software. This was something we did not know, and half an hour of Googling revealed almost nothing other than where to plug the laptop in and how to boot up the software to force the fuel pump to run for an extended period (handy information if you happen to have a VW engineer and his laptop with you, otherwise not so much). Anyway, as is the system on the Autoroute in France, we had to call the French police to arrange recovery from the motorway service area to a "non motorway" location where we could then call our own recovery service.
The very nice French recovery driver arrived about 15 minutes after, and following a quick chat went to his truck and pulled out a can of "Easy Start" (for diesels I imagine) or "Start You B**tard" (I kid you not) and removed the air intake hose after the air filter. He sprayed a very small amount into the air hose and the van started straight away and has run flawlessly since.
The main learning points for us were:
1) Don't trust the "Range" estimate - even on relatively young/low mileage vans
2) Don't run your battery down trying to start the van if you've inadvertently run it dry
3) The van may start (do this at your own risk, I am in know way implying this is sympathetic to
your engine) with the help of an "Easy Start" type product sprayed conservatively into the
engine air inlet
Other than this we had a great trip and we couldn't be happier with the last 5 yrs of ownership!
engine air inlet
