Roof Stuck twisting.Warning...
Actionwave
Actionwave
Novice California Owner
bexley, kent
T5 SE 180
Lowered the roof at the weekend after a night camping, no problem. I then noticed that the driver side was not closed and at an angle...I managed to open and then close properly.
When back at home we opened it but when we tried to close the driver side was stuck fast and the right was closing and the roof was on the verge of buckling.....The driver side slider at the top was stuck, opened the roof fully again, ladder a can of silicon spray later, all good. Am concerned that there was no fail safe mechanism to stop this from happening or alerting me of the issue other than visually noticing just before heading off up the motorway...
Unfortunately there is no real fail safe mechanism it’s always advised to have someone watching the roof while you are lowering it if possible. There are sensors in the lift rams but they only register end positions.
Or stop frequently as you lower it to check & final check of roof before leaving site, at same time I check I have not left anything behind
Thanks, will do in the future, im getting there now with this California stuff!!!
Perfectos
Perfectos
8K
GrannyJen
GrannyJen
Pasper2
Californiaman
Californiaman
Tom Rae
Tom Rae
Tom Rae
Ngarner
Ngarner
Ngarner
