SimonB
Staff member
We went away for 3 weeks, not in the Cali, and when we came back I tried to start it, but there was not enough power in the battery to turn the engine over. I have one of those Clarkes jump starts which started it with no problem at all.
My question is, what could there be that is draining the battery when it is not being used? I have switched off all the courtesy lights that come on when the doors are opened. Our side door is manually not electrically operated. I turn off the control panel. We only use the Cali for longer journeys not short hops.
I don't want to have to keep the large Jump Start with me in the van if I don't move the Cali for a couple of weeks.
What is it that I have missed and not turned off?
Also is the large bolt next to the battery a suitable earth point to put a jump start onto? I read that due to relays, etc, you should put the neutral lead of the jump start onto a well earthed piece of the engine, the leads on the small jump starts are too short to do this, is that bolt a suitable substitute?
