Feng Li
Is grounding cable mandatory for installing an new inverter?
I plan to purchase an inverter to cover my ebike charging requirement. Found one grounding port on the back of inverter (Phoenix Inverter 12/500 230V VE.Direct, or the 1200W version)
If yes, could you share some experience which type ground cable would be sufficient and more important where is the mounting point for VW T6 California. I found some posts mention a place below the fridge, and to get there, the fridge has to be removed. I would love to avoid this complex operation. Any suggestions are welcome. Many thanks!!!
