Shadrack
Hi Guys
An interesting thread. I have wired in a lead with an inline fuse connected directly to
Leisure battery. This makes it easy to plug in my portable(120w) panel.
I also retained a lead with big battery croc clips to use on engine battery and also other batteries on other vehicles should I need it.
I went through various tests at the time of installation. With my dvm connected in series on the amps range the dvm showed just a little over 2 amps charge. This was because the leisure batteries were already in a full state of charge.
I then found a very dull and tired battery from my garage and the current on that went up to 8.6amp. There was not a lot of sun around either..
I have used now on a few trips, each of a couple of days and they easily support the fridge and lights withought the need for hookup.
I don’t have an in-line amp meter whilst I use but the c/p will show 90% during the day with fridge and maybe a phone or iPad charger plugged in.
The rate of charge only goes up if the demand or load is there.
