Max-Felix
Arghh. Was working fine when tested at purchase but since then something has gone wrong. I was sorting a cosmetic issue on the CP that meant I inadvertently pressed the on/off multiple times in a row.
I then got the flashing heater symbol - diagnostics shows 2101 which according to...
https://vwcaliforniaclub.com/threads/error-codes-for-the-vv-cali.38/
...means' fuse output heating on/off'
Anyone know exactly what this means? I presumed fuse gone but checking under seat all the higher fuses (they do not correspond to @Loz 's pic/diagram so not sure exactly which is the heater fuse?!) 25 above seemed OK.
I then cleared it (this was a couple of days ago) and the heater would then start but only blow cold for a few mins and then turn off - this was in the day with our recent 30 deg heat - is the heater thermostatically controlled and therefore was just not needed?
However, here's the odd bit - just went back again today (few days later) as much cooler this morning and pressing the button showed the same flashing symbol.
I switched the CP off (did not reset or clear error) and when I turned it back on and pressed heater - no flashing and it started up. Clicking pump etc and it drew between 8 - 11 or so for the first few mins and then started to produce hot air and after 5 mins or so settled to a steady 3.6 amp draw.
I've left it running and will see how if it stays on but was blowing nice and hot.
Also, does keeping the side door open turn the heater off??
