G
gatvol
- Messages
- 533
We had always struggled to find a decent compact bbq, until now.
Anything with coals is messy, takes time to heat up and may be banned at French campsites. The Cobb has fans, but is too messy and hard to clean imho.
For about 6 years we struggled on with a campingaz partygrill. But this simply did not get hot enough, had no lid and took ages to cook food on due to its poor design. There is a newer version now, but it did not match up to the Cadac.
https://www.leisureoutlet.com/barbe...8MPAjDqPLfz-WenUgz8ly8_U-DcBQs9xoCElsQAvD_BwE
The Cadac is faultless. It packs into a neat bag that is supplied with it. The gas heats a central disc in the griddle that means it gets hot enough and cooks evenly across the grill. The lid then gives the food a nice smokey flavour and greatly accelerates cooking time. It cooks in less than half the time of the partygrill.
It is non stick. It has a griddle to created charred lines on meat and also has a flat pan as well. It is easy to clean and only needs a sponge and washing up liquid.
The HP model (high pressure) is designed to have coleman screw thread cartridges attached directly to it so there is no need for a regulator or bulky cylinder. There is a LP version (low pressure) available too if you want to use it with the big gas cylinder inside your california.
Coleman cylinders are not as readily available in Europe as the campingaz click ones, but you can buy a small adaptor that converts click into the screw thread.
https://m.addnature.co.uk/244004.ht...4_pla&ef_id=WFBrTwAAATGcjRLt:20180618073526:s
