Anchoring dogs to van
cazmatt
cazmatt
Hertfordshire
Has anyone got any good ideas of how to attach 2 dogs to the van with the side door open - bearing in mind usual dog practicalities (ie assuming they will definitely pull on it, and inevitably wrap themselves up and end up with their lead wrapped round their legs/ each other within minutes :headbang)
I have seen some people say around the wheel spokes... Or with a caribiner on the seatbelt mounting loop (but this seems too tight) or the load hook (but on a T6 this seems to need some major removal of pieces)... but this must be a fairly common thing so surprised there isnt a good solution!
For a van, there are very few (or none?) fixing/securing points in the california!
Not sure where but I have seen on here a fixing that is attached in the seat guides that has a metal loop for securing loads etc, would be ideal for a lead.
Thats the good thing about steels....on site at this time looking like this .
No more no less
We also have a anker point to screw in the ground , i belive there are previous threads on this in the dog section .
Cazmatt, you're right that you can only fit a small carabiner clip through the hole in the seatbelt anchor. So we have two clips, a small (50mm) on the anchor point and then a larger (70mm) to attach the dog tether.
They stay in place permanently and it all works just fine.
Genius why didn't I think of that!
G
27K
Hotel du van
Hotel du van
AlisonF
AlisonF
H
6K
BeeBee
Neilos
10K
AMH70
AMH70
