as do the other two which are hopefully still attached to your rack. The one on the right is for the 4th rail, and the clamp goes from bike to bike rather than bike to rack.The left pole fixes to the rack.
Thanks for your help.The left pole fixes to the rack.
Hmm yes, I thought as much after having a brief look at the manual .. I’m taking the van for a service this coming Monday so will ask them then about a replacement part. Shame the previous owner didn’t mention this or reply to my messages, but hey-ho there are worse things. Thanks for your help.it does look like you are missing the block that holds the left arm to the rack. The instruction book shows a breakdown of the part numbers (should find on the web). Being able to look at the other two (still fixed) will help you work out the bits you need. A VW Commercial dealer will supply, as will a TPS depot.
Thanks.View attachment 31263 This is what it’s like in real life
The bolt is already there,
in your first picture, the left pole.
You have to push it through a bit more and squeeze the clamp together a bit.
