Actionwave
Novice California Owner
The runner that keeps the bottom of the Kitchen cupboard sliding doors aligned has come adrift from the bottom of the cupboard,any ideas please???
I presume this is the inside runner. If that is the case it clicks into position. It requires a firm pull towards the outside, towards the vehicle sliding door and it will click into position. Let us know the outcome.The runner that keeps the bottom of the Kitchen cupboard sliding doors aligned has come adrift from the bottom of the cupboard,any ideas please???
Nice and clean too! Excellent!! (Sorry for butting in but cleanliness always helps the smooth running of all parts of the Cali)
Yes. And in the case of the cupboards, a smidgen of silicone spray does no harm either! (Particularly good on the rear tambour door - mine now glides silkily).
Definitely agree. Did mine again yesterday and makes a massive difference. Prior to spraying them I was worried they would break.
Mike
Have you Mike (or anyone else) tried it on the window blind runners? Was meaning to give it a go on our very sticky one over the side door.
Spraying window blinds with silicon or other sprays could lead to blinds not staying down when closed.
Regards from Amsterdam,
Marc.
If you don’t spray the bottom 4” each side you won’t have a problem as that is where the friction catch is that keeps the blinds down.Oooh Mrs VD wouldn't thank me for that...
That was Sherwood Pines Forest Notts at the weekendproving difficult with 2 adults 2 kids mountainbikes and the dog View attachment 31406
Thanks Welshgas has all fixed, I. was trying to clip onto the top edge end not the one beneath , added a bit of silicone all good
All fixed taI presume this is the inside runner. If that is the case it clicks into position. It requires a firm pull towards the outside, towards the vehicle sliding door and it will click into position. Let us know the outcome.
