GregW
I discovered clear water on my T5 SE van floor this morning, perhaps a cup or two, that appears to have come from under the sink unit. Water on the shelf directly under the sink waste and tap plumbing at first seemed to suggest it was coming from there, and the white tap supply pipe was wet where it runs horizontally. So a leak at the tap was my first guess.
However... I've only had the van a couple of weeks and never used the sink, nor have I put water in the tank.
So my next guess is rain water ingress through the window above the sink. It has been raining hard, so is this a common issue?
Does a replacement to the window seal tend to resolve the problem?
