It will cause no harm being hooked up for long periods. Lead acid batteries love being fully charged and the mains hookup charger is a top quality 3 stage unit that will maintain full charge without ill effect.Is there any reason not to leave the van plugged in to hookup at home when not in use (could be weeks at a time?) T6, with bluemotion tech
Yes. Lead acid batteries are best kept fully charged. Assuming VW still fit a 3 stage charger the last stage of charging is float. Float purely tops up/ counteracts the internal losses within the battery. A lead acid battery can be kept on float indefinitely without harm.Great, that being the standard VW one already fitted to the van?
Perhaps some confusion here. Leisure batteries are not (or should not be) lead acid but Gel type. Starter battery is leadvacid obvs.Yes. Lead acid batteries are best kept fully charged. Assuming VW still fit a 3 stage charger the last stage of charging is float. Float purely tops up/ counteracts the internal losses within the battery. A lead acid battery can be kept on float indefinitely without harm.
Gel is a type of lead acid battery.Perhaps some confusion here. Leisure batteries are not (or should not be) lead acid but Gel type. Starter battery is leadvacid obvs.
No problem at all leaving van on hook up.
And south of 66°33′47.1″ North.Or fit a Solar Panel. No problem keeping the Leisure Batteries topped up during winter. Obviously only of use if the vehicle is parked outside with no overhead obstacles.
Obviously you can't "push" electrons. Your point is??“Most DC-DC chargers draw a higher rate of amperage from the alternator than would be supplied if you let the alternator ‘push’ down the cable. This can be up to 40A or more per hour, quickly replenishing the house battery system.”
Hmmmmmm???
Hmmmmmm???
I was raising an eyebrow at the amount of juice it pulls.
Also the article talks of heat in the cables and volt drop making siting of the unit important.
Interesting stuff.
Nothing changes in that respect.Loz, does this arrangement allow the engine battery to be charged by the EHU?
Surely the MGU can be configured to freewheel once the battery is at 100%?
Spinning up the turbo obvs requires an electric turbo but would surely help with economy?
