Amarillo
Tom
Fed up with plugging in an unplugging 12 volt sockets for external awning lighting, I have now rigged up a medium term solution.
Using the rear socket, with the multi-flex slightly forward of its rearmost position, I run the cable under the trim.
It emerges from the trim at the left tailgate hinge and is cable tied to the hinge.
The cable is connected to a switch which is secured to the awning end cap with Velcro, ready for LED lights to be connected to light the wind out awning and driveaway awning when camping.
I have found pitching in the dark difficult. Now all I need do is wind out the awning, attach a light strip to Velcro already in place, connect the light to the switch, turn on the switch and I have light to pitch the driveaway awning.
The Vango lighting system will take up to four LED strips, ample lighting for the wind out and driveaway awning or even an outside eating area during dark and balmy autumn or spring evenings.
