2into1
Née T4WFA. Now without Cali :(
My van has developed a painful cracking noise as I open the driver's door. I wondered if you could help?
There are few discussions on the T4 (5) forum and I've tried the fixes there. (Taking off the roller cap to grease / tightening the 13mm nut on the hinge) but it has persisted. It has clearly occurred in the past as the hinge area is coated in PTFE grease.
I've worked out noise is coming from the roller that glides around the serrated plate on the hinge. The roller is moving but is quite tight and has no vertical play. The one on the passenger side is less tight and has a little vertical play.
On the troublesome driver's side, the roller has a vertical line shown below.
Either the passenger doors roller doesn't have such a ridge, or if it does, it is hidden out of sight (180 degrees).
So it would be a big help if someone could look to see if their rollers show such as vertical ridge. I'm trying to establish if mine has worn the ridge, or if it has just turned itself around.
I can temporarily get rid of the noise, or change the point at which it makes it's horrible noise, by rotating the roller with a pair of mole grips, but it seems to return after a few days, with the vertical ridge again on show.
