dayslikethis
I have previous threads on this ( since August) but this is just to post a quick summary to see if anyone has any ideas;
Aux Heater stopped working with the wording "Heater not possible" on the Cali control panels. Vehicle now at its 3rd VW garage to try and resolve. To date:
1. Control Panel reset done
2. Fuses checked
3. Vents checked
4. New fuel pump fitted
5. 2 x donor heaters fitted, both started and run for about 5 minutes before cutting out.
6. Wiring loom checked
7. Control panel module checked
8. Donor Cali Control panel tried and failed to make any difference
9. Eberspacher specialist consulted
10. Voltage flows OK
Something is causing the aux heater to cut out but no fault code is registered. Vehicle still at garage - technician trying his best and all options including calls to VW technical.
Grateful for any last minute suggestions.
2. Fuses checked
3. Vents checked
