Basic Beach 114
Yes the Thermotop C is the coolant heater, helps the van warm up in winter..
You can get a remote add on kit to run it briefly for a few hundred, limited to 30 minutes though. A few have done the mod I never went through with it in the end after much research.
This video the one, the glass needs sorting out as it's way too transparent.
I have a beach . the webasto is the engine coolant heater . buy a compressor fridge for your beers. doesn't drain the battery too much when your not on hook up and crikey are my beers cold. mine has the eberspacher air heater already fitted top piece of kit and definitely worth retro fitting. you will camp more and longer with one fitted. other than cold beers and a warm night what more do you need? I absolutely love mine and wish I'd done it years ago. and it's yello
The Waeco fridge is a great accessory - we have the CDF25 - its a fab bit of kit and provided you have the 3 seat beach will fit under the multiflex board. If you have the 2 seat, you still have plenty of options.
All i would say is use it before you go for a liner or a topper - its not necessary provided you have some cosy bedding
Then when you are all sorted on that front you can take the next step ;)
stretton-045-jpg.20350
