Folding Mirrors on Ocean T6 MY18
Jason wallace
Jason wallace
Weston Super Mare
T6 Ocean 204 4Motion
I've seen it mentioned on older posts that the mirrors do not fold on locking.
But looking at this Dutch video of the MY18 changes they also report this has now been added (from 5.06)
Did this change make it to the uk version of the ocean which has folding mirrors as standard?
Can anyone with a recent Build confirm?
Agree, picked up my Ocean this week and they fold when you hold the lock button down on the keyfob. Surprised Guy by showing how they unfold when you turn the ignition on. Think this is standard VW stuff, same as my Yeti.
My T5 does this - just need a @Loz!
Ive got an MY18. You can fold the mirrors by turning the mirror adjustment nob to the fold position, or alternatively by holding down the lock button on the key fob for about 2 seconds, then they fold.
Hope this helps
Chris
Hi,
No it's still there - the heat function and the fold function are at about the 11 o'clock and 2 o'clock position on the knob.
Chris
Mine was build May 2017 has fold away mirrors on switch on door but key fob does not work is it the lock button you hold down
Thanks Loz but before letting anyone loose on my data I would want to know which sections of the program would require changing as I am sure most dealers wont have a clue best if we find out and all go to our dealers and tell them what is needed
is this possible and would dealers know what to do
Absolutely no chance of getting a dealer to do it.
You need to find a member near you with VCDS to do it for you.
Yep. Mine is March 2017 and mirrors only fold from inside button. Holding fob lock button does close the windows (if they were open) though.
Then we must hope that at sometime someone will come up with the reprograming information but I suspect it is not easy due to the other electrical modes they have included
I can’t help but notice that your thumbs up smiley faces have dwindled; have they stopped sponsoring you? ;)
I removed a dealer because they are car dealers and not vans mind you they gave me the VW connect unit free but not used there service department yet
I’ve done loads, it not a secret, but the coding won’t mean much unless you have the programmer.
Well when I get back from my holiday I will be in contact , I will look to see if any other changes can be done at same time auto lock ?
thanks
Loz
I picked up my MY18 recently and it has folding mirrors. Salesman said it was standard now.
With Carista, you can set whether they fold automatically when you lock the van (if you want that). Carista cheaper/easier than VCDS, but doesn't offer quite the same scope/flexibility, though most of the good stuff is in there.
For info. France And Swiss Oceans come with electric folding mirrors, but German models do not. It is an option I did not get.
Jealous
My 2016 has folding mirrors, but they can only be operated by the door switch.
Checking the module with my Obdeleven module (more flexibility and cheaper than Carista) there is no option to use the remote, though some later T6 models can be adapted.
@Loz is the vcds guru and has posted details on the T6 forum.
