I've not done this but I think you will need to remove the front passenger seat. If you do don't turn the ignition on as it will cause a check of the air bag and it will generate a fault. You will then either need special equipment or a trip to a dealer to remove the fault and associated bong noise.
To remove the rear Leisure Battery I found using a broad blade wallpaper/paint scraper to ease the battery over the bottom lip made life a lot easier.
Ah solar fitting, how did that go? What system?
That is a great tip! I saw it in an earlier post of yours and used it when fitting my solar charging system last week. I'm not sure I would have figured it out otherwise.![]()
Thanks a lot guys, you rock
Solar is my next mod for sure!
May I ask which kit and how much time you spent installing it?
