T6 CFO
Mike
You can run the cable to the rear camera with out taking any panels off.
One you get to B pillar use something plastic to work the cable behind the panel and then there are three LED lamps remove them and work the cable behind the panel, ( this is all kitchen side ) once you get it to the LED lamp nearest the wardrobe then go to the rear of the vehicle and open the cubboard that houses the gas bottle look up and you will see a gap in the trim close to van roof.
You will need some stiff cable. I used a length of aerial coax left over from another job. At this point you need a bit of patience and work it through and you will see it at the LED light housing attach the cable to it and pull through, nice and steady. From there it is straight forward. I hope this helps all.
Excellent! Followed your instructions and now have a piece of string in place front to back ready to just pull the wire through. Used my most technical piece of kit in my toolbox, a wire coat hanger for the bit from last LED to back of van.You can run the cable to the rear camera with out taking any panels off.
Mike
