TV When Camping
I imagine power draw would be tiny if you leave it connected to a 12v socket. It would stuff up the battery over time though.
Took me enough research but finally found what I was looking for a Huawei 5786. There is a newer model out now a 5787 which is fancier with touch screen but more expensive and does not have a function on it that evidently only the 5786 has which is the option to look for a wifi network first and if not found to then connect 3G/4G.
If it works it may be just what I want as it has the ability for an aerial connection so will operate as a Wi Fi Extender and a hotspot, time will tell.
At worst it should be a fast (when available) 3G/4G connection and it has what I was looking for most a powerful battery 500 hours standby.
Mike
Mike
Good choice!
I had a similar one (I guess I had the 5787) without repeater function and I liked it. Easy to set up and use.
Now using the Netgear AC 81somethkng however as there isn't any roaming fee for EU countries anymore, I only use my SIM card from Germany to go online (use my iphone6 as a hotspot).
I have never had a Mifi device and I won't bore everyone with why I want to do this but I would like to enable permanent wifi to a device in the Cali.
I suspect a Mifi which powers off the 12 volt is the way to go but I would rather not be drawing power. So how long do they as a ballpark figure keep a charge if just sat on but dormant. ?
There will be a device paired with it but not active unless I ask it to be.
Mike
Mine is left plugged in when on the road. Norway 3 weeks. Can't even measure the power draw as my multimeter cannot read that low.
Ref TV in France.
The Satellite signal area 'footprint' was reduced a few years ago making reception difficult south of the Loire roughly. Unless a large dish is used.
Internet isn't an option as an EU agreement blocks French, etc, IP addresses from accessing UK based channels, progress??
Ref TV in France.
We use a VPN, no problems at all watching Iplayer etc in Europe
Radio-active
Julie and Archie
Julie and Archie
Magic Bus
Magic Bus
6K
Anthony1
Anthony1
