CaliforniaSteve
Steve B
The manual says that the water pump fuse must be removed to drain the water system. However the fuse layout under the left hand seat is very different from the diagram shown in the Owner's manual.
How do I locate the correct fuse or can I drain the system without turning the pump off?
) I guess the fuse is advised to be removed so you can't run the tap on empty (although the van is supplied empty with fuse in).
but now we’re winter ready and I know what to do after winter trips.
